It is currently Sat Jul 19, 2025 10:55 pm
Post new topic Reply to topic  [ 142 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Fri Jul 21, 2023 12:03 pm
bcombs510 wrote:
This is the most satisfying scrap plywood thingy. I saw this from Beau Hannam on Instagram but was probably around before then. Rectangle with a hole = no more wobbly router when notching the lining.
Brad
Hmm, reminds me, I have a spare Dremel tool..................
Could cut down the puckering in the nether regions. :shock:
These users thanked the author Colin North for the post (total 3): Kbore (Tue Jan 09, 2024 12:59 pm) • jfmckenna (Sat Jul 22, 2023 11:33 am) • bcombs510 (Fri Jul 21, 2023 2:20 pm)
PostPosted: Sat Jul 22, 2023 11:32 am
I just thought of this today. When you have to take the neck off a fender with the slotted tuning posts to adjust the truss rod tape off the strings so they don't pop off.
It worked.
These users thanked the author jfmckenna for the post (total 4): Kbore (Tue Jan 09, 2024 1:01 pm) • Hesh (Sun Jul 23, 2023 7:33 am) • joshnothing (Sat Jul 22, 2023 4:33 pm) • Chris Pile (Sat Jul 22, 2023 2:54 pm)
PostPosted: Sat Jul 22, 2023 12:38 pm
Cool. I sometimes use a capo to do the same thing.
These users thanked the author Chris Pile for the post (total 2): Kbore (Mon Jul 24, 2023 4:41 pm) • jfmckenna (Sat Jul 22, 2023 12:54 pm)
PostPosted: Sat Jul 22, 2023 1:00 pm
me too. Same thing if I want to pull the pins on an acoustic bridge for something but don't want to pull the strings like if I need to take a little height off of a saddle.
These users thanked the author SteveSmith for the post (total 3): Hesh (Sun Jul 23, 2023 7:33 am) • jfmckenna (Sat Jul 22, 2023 5:02 pm) • Chris Pile (Sat Jul 22, 2023 2:54 pm)
PostPosted: Sun Jul 23, 2023 7:34 am
C*po here as well and it helps keep things sorted nicely too especially on a 12 when you have to pull the saddle because of course everyone in the world and beyond... wants lower action ya know.... ;)
These users thanked the author Hesh for the post: Chris Pile (Sun Jul 23, 2023 10:35 am)
PostPosted: Mon Jan 08, 2024 8:18 pm
Well this thread got buried, so I thought I would revive it.
When I am installing a rosette in the top, I rout out a small area in the center of the sound hole. In this case the purfling is about .065" deep, so I routed the hole out at about .030". I can keep my eye on the little cavity and make sure I don't sand too deep and go through my purfling. In this case I could just look at the ends of the purfling strips, but most times they are matched up at the ends. This one will be hidden by the fret board extension
Another thing I do is sand to final thickness before I cut out the sound hole plug. I don't know why it happens, but if I cut out the sound hole before thicknessing, the area around the sound hole seems to get thinner than the rest of the top. I know you think I am hallucinating, but it happens. :?
These users thanked the author guitarjtb for the post (total 4): Robbie_McD (Mon Dec 09, 2024 2:37 pm) • Kbore (Tue Jan 09, 2024 1:03 pm) • Bryan Bear (Tue Jan 09, 2024 12:57 pm) • rbuddy (Mon Jan 08, 2024 9:19 pm)
PostPosted: Mon Jan 08, 2024 8:56 pm
Online
Here’s a little doodad for making 12 string life a little easier. Just a bag clip and some foam…Image
These users thanked the author meddlingfool for the post (total 5): Kbore (Tue Jan 09, 2024 1:04 pm) • stumblin (Tue Jan 09, 2024 6:17 am) • Terence Kennedy (Mon Jan 08, 2024 10:48 pm) • bcombs510 (Mon Jan 08, 2024 10:44 pm) • J De Rocher (Mon Jan 08, 2024 9:10 pm)
PostPosted: Mon Jan 08, 2024 10:25 pm
That will make 6-string life a lot easier as well. Thanks
These users thanked the author guitarjtb for the post: meddlingfool (Tue Jan 09, 2024 2:19 am)
PostPosted: Tue Jan 09, 2024 4:08 am
I use a length of Velco hook and loop to hold the strings together when taking out pins as well as the capo.
These users thanked the author Colin North for the post: stumblin (Tue Jan 09, 2024 6:17 am)
PostPosted: Tue Jan 09, 2024 9:10 am
First name: Brad
Last Name: Combs
I think I’ve shared this here before, just not in this thread. There are a lot of ways to cut binding and purfling to make a neat joint. I often use Terry’s mini miter box - http://www.kennedyguitars.com/binding-cutting-aid.html
Lately I’ve been using the miter box to get it close and then the last shaving I use a disassembled combo square to trap the binding and keep the cut true and squared up. I cannot remember where I first saw this, maybe here. :)
Brad
These users thanked the author bcombs510 for the post (total 10): Kbore (Wed Dec 11, 2024 5:52 pm) • kfish (Wed Dec 11, 2024 6:33 am) • Terence Kennedy (Mon Dec 09, 2024 4:01 pm) • Robbie_McD (Mon Dec 09, 2024 2:38 pm) • Barry Daniels (Tue Jan 09, 2024 1:32 pm) • Bryan Bear (Tue Jan 09, 2024 12:59 pm) • J De Rocher (Tue Jan 09, 2024 11:48 am) • doncaparker (Tue Jan 09, 2024 9:44 am) • SteveSmith (Tue Jan 09, 2024 9:26 am) • DennisK (Tue Jan 09, 2024 9:25 am)
PostPosted: Tue Jan 09, 2024 9:41 am
Just another option. I have always used a chisel in the past but for the last few I made something similar to what Kennedy uses. The jig has a groove for the purfling and I cut both the binding and purfling at the same time. The saw you use makes a big difference, I use a veneer saw and I don't do any additional trimming.
These users thanked the author SteveSmith for the post (total 4): Robbie_McD (Mon Dec 09, 2024 2:50 pm) • Kbore (Tue Jan 09, 2024 1:07 pm) • bcombs510 (Tue Jan 09, 2024 10:04 am) • doncaparker (Tue Jan 09, 2024 9:45 am)
PostPosted: Tue Jan 09, 2024 9:50 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Great tips, Brad and Steve! I use my disc sander to square the ends of bindings and purflings before putting them on the guitar, which works great for the butt end of the top (since the neck end doesn’t matter) and one end of the back, but the other end of the back always has to be done on the guitar. I’ll have to try these ideas out!
These users thanked the author doncaparker for the post (total 2): SteveSmith (Tue Jan 09, 2024 10:10 am) • bcombs510 (Tue Jan 09, 2024 10:04 am)
PostPosted: Mon Dec 09, 2024 2:49 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Here's one I have to share....
For all of the tops I have joined so I have used the simple method of 3 wedges on a workboard to bring the plates together.
Because there is no top pressure to align the joint, sometimes they are not perfect.
The plate are thick enough that that is not usually a problem.
Yesterday I thought - why not join the plates in the go-bar deck to provide some overhead clamping pressure?
So I did, and the results were perfect! Super easy to do with my existing setup.
Very happy...
These users thanked the author Robbie_McD for the post (total 4): Kbore (Wed Dec 11, 2024 5:53 pm) • Hesh (Tue Dec 10, 2024 5:33 am) • bcombs510 (Mon Dec 09, 2024 7:24 pm) • rbuddy (Mon Dec 09, 2024 2:54 pm)
PostPosted: Mon Dec 09, 2024 7:03 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I use the tape method but also do that on the gobar deck with a packing tape covered piece of 3/4" x 1" ply (I'm a little sloppy with the glue). The deck is also covered with packing tape under the joint. I see Rob has waxed paper under it.
These users thanked the author CarlD for the post (total 3): Cal Maier (Tue Dec 10, 2024 12:13 pm) • Robbie_McD (Tue Dec 10, 2024 8:02 am) • bcombs510 (Mon Dec 09, 2024 7:24 pm)
PostPosted: Tue Dec 10, 2024 6:56 am
4 aluminium sash clamps and some of my planes, greaseproof paper on the 18mm MDF underneath is my choice too.Image
Sent from my moto g(50) using Tapatalk
These users thanked the author Colin North for the post: Robbie_McD (Tue Dec 10, 2024 8:03 am)
PostPosted: Tue Dec 10, 2024 7:56 am
Last Name: Parker
City: Charleston
Lots of ways to keep the two sides of the top or back from popping up. I stretch large silicone rubber bands on both sides of the seam, parallel to the seam, anchored by dowels in the edges of the backing board. This provides plenty of downward pressure, but allows the wood to move side to side so the seam can go together well. I’ve used a few different types of clamping pressure, but I keep coming back to simple wedges along the far side of one half and a flat, straight board along the far side of the other half. Effective, easy to modify for odd shaped parts, and really fast to apply the pressure, which is important when you are working with hide glue.
These users thanked the author doncaparker for the post: Kbore (Wed Dec 11, 2024 5:55 pm)
PostPosted: Tue Dec 10, 2024 8:07 am
First name: Rob
City: Cochrane
State: Alberta
Thanks Don, I like that idea of using those long silicone rubber bands anchored by dowels in the backing board to apply seam pressure..
I will keep that in mind if I don't feel like setting up the go-bar deck only to join a top...
These users thanked the author Robbie_McD for the post: doncaparker (Tue Dec 10, 2024 8:44 am)
Users browsing this forum: Chris Ide, meddlingfool and 17 guests
